Home > In Car Electronics (L405) > Failed 22a Software Update
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Quote:
Downloaded the 22a software, but it after an hour, it hasn’t installed. This morning was initially met with dead screens (now back to life), but it’s still on 21b.
Is there a way to force the install?
Edit - it’s updated itself now.
Post #678973 29th Nov 2023 11:18am
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Is that the 1/12/22 update? Is there no more recent update now that Pivi Pro reigns supreme. Are those of us with In Control now considered to be not worthy of software updates? Grr!
Post #686040 20th Feb 2024 11:18am
Gremlin500
Hi Nubbin,
Yes, I’m afraid you are correct.
But, every cloud has a silver lining as they say: 22A seems to be pretty trouble-free and stable, and if further “updates” were made available, knowing JLR, they’d probably only introduce further issues Laughing
In the past I always used to be a zealous “updater”, but nowadays, in total contravention of my footer below, as far as electronics are concerned, I stick with whatever’s not currently causing me grief!
Mechanical stuff? Well, that’s another story………. Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #686043 20th Feb 2024 11:31am
nubbin
I agree with that for sure! I've just had the free security update done on mine, and asked the dealer about updates - they thought I meant vehicle software and gave me a "If it ain't broke..." line, saying that if they updated the vehicle and something didn't work, it could easily cost ME (!) £2-3000 to fix!
I wish I could just update my software to Pivi Pro but it's an entirely different system, and the only thing that irritates me about ICTP is the dreadful satnav system, with it's amusing pronunciations of place names, and routing down the tiniest side road to save 1 second of driving. Oh and the terrible lag particularly on start-up, which can take up to a minute to get going. And asking you to log in with passwords when you're hurtling down the motorway. Shocked
Post #686058 20th Feb 2024 2:07pm
Philip
Never bothered with the car sat nav, always have Waze on CarPlay. As for 22a, connection etc seems fine, but it does very occasionally simply not work when you turn on the ignition - two black screens which need a turn off-lock-unlock-turn on again.
Post #686083 20th Feb 2024 6:20pm
LiKuid
Greece 2017 Range Rover Autobiography TDV6 Corris Grey
Anybody knows if i can reinstall an already installed software version?
After numerous attempts, I managed to get to S22A_22.32 which is the latest available, but i cannot get carplay to work…
Maybe reinstalling could make a difference, but i cannot find such an option
Post #706341 7th Dec 2024 8:14pm
would a battery disconnection help? ... - .- -.
Post #706346 7th Dec 2024 8:53pm
Gremlin500
@LiKuid:
No offense intended, but you are aware that Apple CarPlay on the 2017 is only with a USB cable, it’s not wireless?
I upgraded my own MY2017 with this wireless module, which is great:
Post #706357 7th Dec 2024 10:50pm
Gremlin500
As per this thread:
https://www.fullfatrr.com/forum/topic70627.html
Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #706359 7th Dec 2024 11:59pm
LiKuid
Gremlin500 wrote:
@LiKuid:
thanks for that. I know that it is wired, although i ve forgotten about it in the first place.
The thing is that given i ve got a usb-c iphone, i used a non genuine USB A to C cable which also may cause issues. So, i used my wife's iphone (lightning) with a genuine cable but still to no avail... Both USBs should work for carplay. Correct?
Post #706367 8th Dec 2024 7:47am
Gremlin500
Is Carplay enabled on the phones, and in the car menu? “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #706368 8th Dec 2024 7:59am
LiKuid
How do you enable carplay in the car menu?
The iphone works via carplay in my other vehicles, so dont think there's anything to enable there.
Post #706371 8th Dec 2024 8:04am
Gremlin500
I had a LOT of problems updating software, caused by lack of voltage from a weak battery, as soon as I changed the battery, everything worked perfectly, so check the. Battery SOH (rather than SOC). Switching on the ignition without the engine running will cause a drop of almost one volt, so if battery is old, it may be too low. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #706372 8th Dec 2024 8:05am
Gremlin500
You may need 22A for Carplay, maybe someone can confirm? “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #706373 8th Dec 2024 8:07am
LiKuid
I am on S22A_22.32
The update was performed while driving in order not to drain the battery. I used the Iphone's 4g as a hotspot
Post #706374 8th Dec 2024 8:11am
