![]() | Home > General (L405) > L405 4.4 as a farm vehicle |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2555 ![]() ![]() ![]() |
I don't have a L405 but would if I had any reason to replace my MY12 4.4 TDV8 L322 that is my all-purpose vehicle including farm work, but I suggest that you find one with an e-diff. I retrofitted an e-diff because I didn't like the behaviour on muddy tracks compared with my previous 3.0 D4 that was ordered with an e-diff. |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 186 ![]() ![]() ![]() |
I think the DPF might not agree with farm travels, fine if you can drive a steady speed for a while to clear it out but pottering over tracks is not really ideal.
Rock Member Since: 27 Nov 2023 Location: Tyrone Posts: 2 ![]() ![]() |
It would get plenty of towing and heavy work that should keep it cleared?
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 294 ![]() ![]() ![]() |
Well I certainly couldn't think of a better vehicle to tow something for 1000 miles TBH!!! FFRR SDV8 Autobiography |
It seems that city driving is what causes most of the DPF problems, regular long distance journeys will certainly keep your DPF clear. |
....Plus you need to make sure that 2nd turbo kicks in frequently too, avoid a sticking valve!
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 141 ![]() ![]() ![]() |
I owned a L322 TDV8 before moving on the a L405 SDV8. On our farm we also have a Mitsubishi L200 and that is the go to for trailer work and mud plugging over the L405 because its a lower value car so it doesn't matter if it gets scratched and dinged. The L405 stands in fine when needed.
