![]() | Home > In Car Electronics (L405) > Screen just died... |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
I would try the battery disconnect trick…disconnect it and leave it disconnected for a few minutes then you touch positive and negative cables together before reconnecting battery. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
in addition to the battery idea above, you might find a low power battery will not boot up 12v sockets and other electronics including the infotainment screen..
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 ![]() ![]() ![]() |
Which battery to disconnect or both ? The main battery is new and the car was being used, so not a low volatge issue I'd have thought. It just stopped working after having used the car, jumped back in 20 minutes later and no screen or systems off it. Since then used it a few times and it's dead.
