Home > In Car Electronics (L405) > Screen just died...
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Screen just died...
My 2014 L405 infotainment screen just died, nothing, not a sausage. Any pointers before I start taking things apart ?!
Thanks
Post #678217 18th Nov 2023 12:16pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
I would try the battery disconnect trick…disconnect it and leave it disconnected for a few minutes then you touch positive and negative cables together before reconnecting battery. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #678248 18th Nov 2023 9:26pm
in addition to the battery idea above, you might find a low power battery will not boot up 12v sockets and other electronics including the infotainment screen..
did the screen come back on when you had travelled some time? ... - .- -.
Post #678250 18th Nov 2023 9:52pm
Ragingrover
Which battery to disconnect or both ? The main battery is new and the car was being used, so not a low volatge issue I'd have thought. It just stopped working after having used the car, jumped back in 20 minutes later and no screen or systems off it. Since then used it a few times and it's dead.
Update, disconnected both (as above) to be safe and sure enough it's back to life. My main battery is new, the Aux is the original I think. Could that be the culprit ?
Thanks for the pointers chaps, as ever it's appreciated.
Post #678261 19th Nov 2023 9:23am
