Home > Technical (L322) > Strange oil leak 2011 4.4 tdv8 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3071 |
The oil pump is below that and they can develop leaks. 2012 TDV8 Vogue (L322) |
15th Nov 2023 5:47pm |
Mariusses Member Since: 09 Nov 2020 Location: Berkshire Posts: 20 |
Thanks JayGee. I did try to have a look under all those hoses and cables but couldn't spot anything.
15th Nov 2023 5:57pm |
It's driven by the aux belt so is well hidden. I'm not saying it 'IS' the oil pump but it's a good possibility. Download the workshop manual from the bottom part of the WIKI section
15th Nov 2023 6:12pm |
Thanks.
15th Nov 2023 6:45pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 393 |
My throttle body to intake manifold gasket was leaking and blowing backward, similar to how yours looks. 3€ and 15 mins to change, did this last week 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
15th Nov 2023 7:49pm |
LRworkhorse Member Since: 24 May 2024 Location: Hamble Posts: 5 |
Did you find out what was causing it ? |
24th May 2024 10:43pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2405 |
I suspect a split connecting tube or split seam in the donut.
25th May 2024 8:19am |
As in the split in the rubber hose connecting plenum and intake manifold? |
26th May 2024 10:21am |
Yes. |
26th May 2024 10:34am |
