Home > Technical (L322) > Strange oil leak 2011 4.4 tdv8
Mariusses
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I was wondering if anyone else has experienced this strange oil leak on the left hand side- (drivers side) front of the engine? The whole engine cover is full of oil in that area.
There is no dripping on the driveway just on the top of the engine and it seems that is getting spilt all over by the fan.
Any ideas ?
Many thanks.
Post #678000 15th Nov 2023 3:41pm
JayGee
The oil pump is below that and they can develop leaks. 2012 TDV8 Vogue (L322)
Post #678004 15th Nov 2023 4:47pm
Mariusses
Thanks JayGee. I did try to have a look under all those hoses and cables but couldn't spot anything.
Is there any particular spot i should look at ?
Thanks.
Post #678006 15th Nov 2023 4:57pm
JayGee
It's driven by the aux belt so is well hidden. I'm not saying it 'IS' the oil pump but it's a good possibility. Download the workshop manual from the bottom part of the WIKI section
https://www.fullfatrr.com/wiki/Main_Page
and it will show you where everything is. 2012 TDV8 Vogue (L322)
Post #678007 15th Nov 2023 5:12pm
Mariusses
Thanks.
I will have a look at the wiki now. It makes sense why the drive belt is squeaking in the morning when the car its started Shocked
Post #678010 15th Nov 2023 5:45pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
My throttle body to intake manifold gasket was leaking and blowing backward, similar to how yours looks. 3€ and 15 mins to change, did this last week 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #678012 15th Nov 2023 6:49pm
LRworkhorse
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Re: Strange oil leak 2011 4.4 tdv8
Did you find out what was causing it ?
Post #693274 24th May 2024 9:43pm
GraemeS
I suspect a split connecting tube or split seam in the donut.
BTW, the oil pump is driven internally directly by flats on the crankshaft.
Post #693281 25th May 2024 7:19am
LRworkhorse
As in the split in the rubber hose connecting plenum and intake manifold?
Post #693344 26th May 2024 9:21am
GraemeS
Yes.
Post #693345 26th May 2024 9:34am
