Home > Technical (L322) > Suspension fault flooded wheel well l322 2011 4.4tdv8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I'll comment what I can, my old 322 was drowned in a Welsh river with water up to just below the seat base, the whole boot was under water.... The compressor carried on working and put a lot of water into the suspension... the faults that came up were many and they are all hard faults... This means you have to fix the fault then use a diagnostic tool to clear the faults, they will not clear on their own or by disconnecting the battery... it took multiple goes to fill the suspension with air, then vent it to remove all the air, then dry out the crystals and start again until they remain dry, all the while having to use a diagnostic tool to clear faults and vent the system... It took a lot but it did work and sorted the system out....
8th Nov 2023 7:13pm |
ajtotal Member Since: 16 Dec 2020 Location: murowana goslina Posts: 4 |
Thanks, I think I need to add that it throws C1A20 (buildig pressure too slow) but IMHO it is not the case. The compressor does not die overnight. It worked right after the flooding. I suspect a valve being stuck open/closed (i dont know) or no voltage supply to the solenoid |
8th Nov 2023 8:41pm |
AN UPDATE! For posterity: I kept looking for the problem in all sections of the vehicle slowly forgetting that I flooded the wheel well and most likely I should have been looking in that particular spot. Denial is not just a river in Egypt, C1A20 (slow pressure buildup) turned out to be the right trail. I eventually disassembled the entire compressor unit and found out the plate valve on the compression side of the piston broke off, probably due to the presence of water, which is not as compressible as air. I renewed the entire piston assembly incl. the 4 rings (the valve is pressed into the piston and cannot be replaced). Now the suspension works perfectly. I also found out that my compressor before the repair was on its last legs anyway and the water only accelerated what was inevitable. The height change is like 10 times quicker than before. For those who do not believe I say it is an easy job except one tricky thing with removing the piston and pressing it back onto the electric motor. A hydraulic press would come in handy. Other than that I made all the repair on my office desk with a few tools really. Good luck to those who are not afraid..... |
11th Nov 2023 11:35am |
