Suspension fault flooded wheel well l322 2011 4.4tdv8 | |
Hello. This post goes out specifically to guys who know their way around the suspension system in our vehicles (2011 4.4tdv8) and perhaps even had an issue like mine and understand how individual parts of the system operate. I am having a problem with the suspension. Found out two days ago that the wheel well was filled with water. The compressor was virtually flooded. Yet the car worked fine (the water must have been there for like months) and suddenly BOING 'suspension fault'. I immediately began drying the well. The compressor kept slurping like crazy but it did start working. I cycled the air ride several times to vent the system and went to bed. The next day i finished cleaning the well and started the engine- BOING air 'suspension fault'. This time I dropped the vehicle to access mode to vent it again stupidly not leaving any air for emergency drives and ever since it has been in this mode irrespective of the height setting. When you drive above 40kmh the system wants up but it cannot and the central display very rapidly interchanges between access and normal. The above I totally understand- the system is confused getting implausible information. I have been looking for the problem for like 2 days now only to find that one of the wires leading to the air compressor solenoid valve block was rusted and snapped. Alright I say we have the culprit! I reattached the wire and....... BOING suspension fault again. BTW, I disassembled the compressor dried out the desiccant and refitted it in the vehicle
The symptoms: The vehicle starts I set the height, shut the door and the compressor starts to work, builds the pressure and stops.The vehicle does not rise. The most probable cause is that there is some short circuit in the system due to water ingress. What I need is a crash course in what does what in the system. My understanding is that one of the valves is not opening and does not feed compressed air to the system, when the pressure exceeds the limit it stops and the fault comes on. I seriously suspect the rear solenoid valve block (the one attached to the compressor, the one with the snapped wire). There are three lines - two green and one black. I need to know what it does. The solenoid is dead (0.34v or something), even though I reattached the wire. Should it be dead when the compressor starts? Maybe it is not supposed to be active when the pumping begins, I dont know, but I need to know this before I go any further. Any help appreciated.
