Home > Technical (L322) > 4,4 Tdv8 Cylinder compression test? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3112 |
On an older car that’s done a few miles I’d be more concerned that they were all similar rather than comparing them to the factory original specs.
5th Nov 2023 11:28pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
What matters with compression is that they're all within tolerance of each other, not what specification said 100,000 miles ago. 2015 Range Rover Autobiography 4.4 SDV8 |
6th Nov 2023 9:46pm |
To a point, yes - there needs to be a baseline for things to 'work' but the high to low isn't bad. What matters is the relative compression and cylinder contribution. It's also not good to have the highest contributor next to the lowest contributor in the firing order. ~300psi is pretty much the low end of diesel compression limits at 16.1:1 and 60psi is generally the acceptable maximum high to low range variance.
6th Nov 2023 10:09pm |
EstRR Member Since: 09 Mar 2022 Location: Estonia Posts: 3 |
The problem lies in the crankcase ventilation and pressure.
9th Nov 2023 6:26am |
In that case a cylinder leakage test would be most appropriate, the compression figures are not a good way to determine the rate of leakage as they rely upon movement. |
9th Nov 2023 7:15am |
