Home > Maintenance & Mods (L405) > UK L405 SDV8 Right Hand Turbo Replacement |
PHG Member Since: 20 Oct 2016 Location: Marple Posts: 15 |
Hi I'm about to set out and replace the variable turbo on the right. Research shows step 1 is remove engine. Does anyone have any tips or knowledge if the replacement can be done from underneath without removing the engine? Google is a bit light on info. 2015 SDV8 AB
4th Nov 2023 5:28pm |
Any information would be appreciated if you know of any successful DIY right side turbo change. Cheers, 2015 SDV8 AB
5th Nov 2023 7:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
i put 'turbo replacement' into our search and it came up with these threads...should be some thing that will help you,
5th Nov 2023 8:09pm |
Hi Stan thank you very much for the reply and help, loads of info on L322, I'll look through the wiki too. 2015 SDV8 AB
5th Nov 2023 8:49pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
Interested to know why you are having to change the turbo. |
16th Mar 2024 8:29am |
Hi, sorry I thought I’d reported back.
16th Mar 2024 8:35am |
Daveyp Member Since: 11 Mar 2024 Location: Stevenage Posts: 3 |
Thanks both for the replies,
16th Mar 2024 9:16am |
Mines a l405 so no experience of turbo access on l494.
16th Mar 2024 9:30am |
Thanks for getting back to me PHG. I’ll get it properly diagnosed and report back here for anyone in the future. |
16th Mar 2024 9:38am |
