![]() | Home > Maintenance & Mods (L405) > UK L405 SDV8 Right Hand Turbo Replacement |
PHG Member Since: 20 Oct 2016 Location: Marple Posts: 15 ![]() ![]() ![]() |
Hi I'm about to set out and replace the variable turbo on the right. Research shows step 1 is remove engine. Does anyone have any tips or knowledge if the replacement can be done from underneath without removing the engine? Google is a bit light on info. 2015 SDV8 AB
Any information would be appreciated if you know of any successful DIY right side turbo change. Cheers, 2015 SDV8 AB
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35495 ![]() ![]() |
i put 'turbo replacement' into our search and it came up with these threads...should be some thing that will help you,
Hi Stan thank you very much for the reply and help, loads of info on L322, I'll look through the wiki too. 2015 SDV8 AB
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1272 ![]() ![]() ![]() |
Interested to know why you are having to change the turbo. |
Hi, sorry I thought I’d reported back.
Daveyp Member Since: 11 Mar 2024 Location: Stevenage Posts: 3 ![]() ![]() |
Thanks both for the replies,
Mines a l405 so no experience of turbo access on l494.
Thanks for getting back to me PHG. I’ll get it properly diagnosed and report back here for anyone in the future. |
