Home > Maintenance & Mods (L405) > L405 automatic forward parking sensors
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
Help
As the title suggests I am trying set the forward parking sensors to come on automatically, I know they operate when reverse is selected, but I want them to come on when pulling into my drive.
copied from the handbook
By pressing and holding the Parking aid switch for three seconds, the Parking aid system enters into an Auto-on mode, activating the front and side sensors when the vehicle's speed decreases to less than
10 km/h (6 mph), in a forward direction
so in theory it is possible, but I have tried pressing the button all ways, with ignition on and off but can't get them to activate automatically. has any one achieved this ?
if so could you give me some guidance as what I'm doing wrong various other LR's this one is still the best
Post #677170 3rd Nov 2023 2:43pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Not sure what year you’ve got, but on my ‘17 model the setting is within the parking sensor settings.
From memory:
So I select reverse.
When the parking sensor screen come on.
Press the settings icon.
Activate the allow speed setting.
Hope this helps 2017 (67) Vogue SE Corinthian Grey
Post #677229 4th Nov 2023 12:32pm
philbathurst
mines a 2016 will give this a try - thanks various other LR's this one is still the best
Post #677231 4th Nov 2023 1:08pm
philbathurst
this might help others,
I eventually stumbled across the option "auto parking aid" in one of the main menus, with it set to "on" the front parking sensors automatically operate when speed under 10mph issue resolved,
but there is no mention of this option in the online handbook various other LR's this one is still the best
Post #679521 5th Dec 2023 11:26am
thanks for the info Thumbs Up ... - .- -.
Post #679522 5th Dec 2023 11:35am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I have this also on my 2016, but as soon as the ignition is cycled the setting reverts to off, meaning everytime you get in the vehicle you have to select on, makes it a bit pointless in my opinion.
Has anyone managed to select Auto Parking Aid On and got it to 'stick'?
Thanks L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #679523 5th Dec 2023 12:20pm
philbathurst
oh dear not checked that, might have to resort to the iid tool to see if it can be set to permanently on various other LR's this one is still the best
Post #679524 5th Dec 2023 12:30pm
4RRS
I'd be interested to know if yours is the same. I looked through the CCF via IID and couldn't see anything that looked likley to make the setting permanent Big Cry L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #679526 5th Dec 2023 12:33pm
philbathurst
just used the iid tool to look at the CCF files, I have access to the complete CCF given by Partrick Meilleur:
in the "full list" I searched for "parking aid" there are 2 items listed, made the necessary changes, I have auto park assist also,
set options so it shows I have both systems, uploaded CCF and now the Auto parking aid stays on all the time, it does not default to off with ignition cycle
hope this is useful, I have not checked the auto park assist, but I never use that anyway various other LR's this one is still the best
Post #679540 5th Dec 2023 2:25pm
4RRS
Would you mind listing the values you changed, think when I looked I only had the confirmed list, whereas I now have the full list as yourself.
Many thanks L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #679542 5th Dec 2023 2:58pm
philbathurst
in the "full list" I searched for "parking aid" it gave me a list of about 8 items items If I recall there was a parking aid module which i altered, I think the other one was parking aid system which i also changed, it was fairly obvious which ones to change,
but I did alter it a couple of times as after upload the first time I got a couple of unrelated faults displaying on the dash eg ABS fault, ACC fault, which after changing the selected options disappeared, I get a little nervous of changing the CCF files so I always save the current settings before I make any changes various other LR's this one is still the best
Post #679545 5th Dec 2023 3:23pm
4RRS
I know the feeling! I'll have a look through my CCF and see if I can spot anything obvious. Glad you managed to sort it anyway. Just have to ask yourself the reason LR thought not to do the job properly in the first place!
Post #679546 5th Dec 2023 3:31pm
4RRS
Re: L405 automatic forward parking sensors
philbathurst wrote:
Help
Just in case this helps anyone else out - The above is valid for MY2014-2015, did this in my L494 and worked a treat, that's why I'm abit miffed that I can't get it to 'stick' in my MY2016 L405 L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #679551 5th Dec 2023 4:46pm
Thanks for sharing...
I remember this used to come on automatically on our old Disco 3 & 4's... Thumbs Up
Post #679590 6th Dec 2023 12:48am
philbathurst
I have report that my previous statement was incorrect,
It appears I have not manged to set this option to be permanently on, it resets back to off with each ignition cycle, I think I will now give up trying various other LR's this one is still the best
Post #679901 9th Dec 2023 6:22pm
