![]() | Home > Maintenance & Mods (L405) > L405 automatic forward parking sensors |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 139 ![]() ![]() ![]() |
Help
mines a 2016 will give this a try - thanks various other LR's this one is still the best |
this might help others,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
thanks for the info |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 301 ![]() ![]() ![]() |
I have this also on my 2016, but as soon as the ignition is cycled the setting reverts to off, meaning everytime you get in the vehicle you have to select on, makes it a bit pointless in my opinion.
oh dear not checked that, might have to resort to the iid tool to see if it can be set to permanently on various other LR's this one is still the best |
I'd be interested to know if yours is the same. I looked through the CCF via IID and couldn't see anything that looked likley to make the setting permanent |
just used the iid tool to look at the CCF files, I have access to the complete CCF given by Partrick Meilleur:
Would you mind listing the values you changed, think when I looked I only had the confirmed list, whereas I now have the full list as yourself.
in the "full list" I searched for "parking aid" it gave me a list of about 8 items items If I recall there was a parking aid module which i altered, I think the other one was parking aid system which i also changed, it was fairly obvious which ones to change,
I know the feeling! I'll have a look through my CCF and see if I can spot anything obvious. Glad you managed to sort it anyway. Just have to ask yourself the reason LR thought not to do the job properly in the first place!
Just in case this helps anyone else out - The above is valid for MY2014-2015, did this in my L494 and worked a treat, that's why I'm abit miffed that I can't get it to 'stick' in my MY2016 L405 L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Thanks for sharing...
I have report that my previous statement was incorrect,
