Home > Technical (L405) > Heater blowing cold air
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Hi I have a 2013 L405 SDV8 4.4. When I set heating to hot the fan will run but no hot air. The car has a coolant leak (1 litre top up every 500miles) but I am careful to top up as soon as low coolant light comes on. Any advice to point me in right direction of possible causes would be great
Thanks
Post #676978 1st Nov 2023 9:59am
Dolphinboy
Thermostat sticking?
Post #677009 1st Nov 2023 2:51pm
Phoenix
Fix the coolant leak first, there's probably a vapour lock in the heater circuit or the diverter valve is not functioning correctly, but TBH, with a leak, none of the coolant circuit can be relied upon to work as intended.
Post #677016 1st Nov 2023 3:54pm
