Home > Maintenance & Mods (L405) > Rear wiper servicing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
i think the rear wiper must be the most forgotten maintenance item...
31st Oct 2023 10:03am |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1506 |
Yes it’s very common for the rear spring pivot to seize up, so almost zero downforce pushing the blade against the glass. I found it better to remove the arm (see WM in the Wiki above) and treat it with ACF-50 which lasts much longer than WD40. Being off the vehicle allows the joint to be thoroughly manipulated to get it nice & free, and it’s then simplicity to change the blade at the same time. A good job to do now, before Winter sets in! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
31st Oct 2023 10:05am |
It’s not the squirting that’s the problem, it’s the dribbling afterwards! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
31st Oct 2023 10:07am |
