![]() | Home > General (L460 2022) > L460 activity Key |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
As far as I’m aware this isn’t available on L460. |
Crocs Member Since: 29 Jan 2022 Location: Ayrshire Posts: 109 ![]() ![]() |
Are the functions available on an Apple Watch? |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2607 ![]() ![]() |
Certainly was an option (066CA) and compatible - either a supply constant or security thing, I imagine. |
D3fin4 Member Since: 30 Oct 2023 Location: Gold Coast Posts: 16 ![]() ![]() |
Strange, since ALL other models still do have it, and the previous 2020 ATB had it.
EdJ Member Since: 30 Jan 2015 Location: London Posts: 362 ![]() ![]() |
Good question. The Apple Watch app has the "start climate", "unlock" and "beep and flash" functions, so I wonder whether you can leave the key in the car and then lock it with the Watch? That was effectively what the Activity Key did, I think? 2024 Range Rover P550e AB |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1451 ![]() ![]() ![]() |
Try these guys they do a retrofit for activity watch for L460
Unfortunately, they retrofit only in UK NL, PH, |
Thats a pain sorry, didnt realise, but it does mean that it can be done |
Yep,thanks |
I just tried the Apple Watch app with my Defender and it works! I put the key in the car and then locked it using the Apple Watch. Walked off and then came back and unlocked it again using the Watch.
The beauty of the activity watch is you can go surfing with it. |
Contact at GAP Diagnostics says they should be able to code the Activity Key to L460 as it uses the same ECUs as other platforms |
Not that I ever have, but you can of course go surfing wearing your Apple Watch too. So I guess, it's similar functionality? 2024 Range Rover P550e AB |
