Home > Technical (L405) > SDV8 gearbox kicks down too easily
Iceboy74
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Hi All,
I've had my L405 for about a month now and done a couple of long runs on the motorway.
One thing I've found, which might be a character of the car and gearbox, is that even with gentle throttle inputs the gearbox kicks down.
Example, if I'm driving at 70mph and want to increase speed to say 80, even with a gentle flex of the right foot the gearbox will kick down a gear.
I thought it would just use the torque and not have to kick a gear down?
I've owned various diesels many with less power and cylinders and they don't have a need to drop a gear.
So, is this normal? I always drive in D by the way.
Otherwise, what a magnificent place to be on a long journey.
Iceboy
Post #676819 30th Oct 2023 8:48am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
It is an 8-speed gearbox so it is quite easy and normal to change from 8th to 7th. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #676831 30th Oct 2023 10:33am
fisha
Yeah, I’d say it was common practice. If you’re cruising and maintaining speed for an uphill it’ll hold the gear. If you want to accelerate and gain speed then it’ll drop a gear to do it. V8 or else ...
Post #676855 30th Oct 2023 2:44pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
This is one thing I preferred on my Disco 4 6 speed to the D4 8 speed. Fewer kick downs and just used the torque.
Post #676856 30th Oct 2023 3:05pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
If I’m using mine on cruise or just normal motorway stuff and see a slight incline ahead I just flick the right steering wheel paddle to keep it in 8th gear and use the torque instead of the very unnecessary change down 2016 4.4 diesel
Post #676868 30th Oct 2023 7:13pm
Iceboy74
Thanks All.
Iceboy
Post #677134 3rd Nov 2023 8:35am
