Home > General > Help needed with my IIDTool |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3252 |
You could try a cheap OBDII reader to see if it's the OBD port? 2012 TDV8 Vogue (L322) |
27th Oct 2023 9:53am |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 587 |
Sorry, I should have said the port seems to be fine, my icarsoft and a cheap device work just fine.
27th Oct 2023 10:01am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Mine was a bit hit and miss when I used to plug it directly into the OBD port, but has been 100% fine since I bought a short OBD extension cable off eBay.
27th Oct 2023 11:55am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35373 |
thats a good tip Mike... ... - .- -.
27th Oct 2023 12:33pm |
@Mike.
27th Oct 2023 12:54pm |
That would work fine, but mine is a bit shorter.
27th Oct 2023 1:11pm |
I have been using an extension cable from the day I got the car due to the poor condition of the cars socket, but this finally gave up so I soldered a new connector in place. So its just my IIDTool giving problems.
27th Oct 2023 1:35pm |
OK that was too much to hope for, it does not work in the new socket without the extension.
27th Oct 2023 2:02pm |
What are the voltages with the Icarsoft so you can rule out the battery? 2012 TDV8 Vogue (L322) |
27th Oct 2023 3:04pm |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 |
I had the Icarsoft LR V3 and it gave me errors like that when I plugged it in on 2 occasions ! The faults were not there until I plugged it in (just to make it clear) I returned it to the Ebay seller and that was that. |
28th Oct 2023 7:44pm |
Yep just the same all is good unplugged
28th Oct 2023 9:10pm |
Hi all, I hate bumping threads, but I am still in need of help.
8th Nov 2023 12:31am |
I don't have an IID but you're welcome to plug yours into my car to see if the issue is still there - I'm working on Saturday |
8th Nov 2023 7:11am |
Many thanks, will pm you
8th Nov 2023 11:46pm |
