Home > Technical (L322) > 5.0 Supercharged Hesitation
dhallworth
My Range Rover has a strange hesitation when at low revs under load. I vaguely remember noticing what I thought was a misfire when climbing the hill to the farm the night I bought the car. I put it down to it needing the timing chains doing and didn’t think any more of it.
The night I drove it for the first time after doing the chains I thought I noticed it again when climbing the lane.
I can now confirm that there is indeed a hesitation on the car. Most of the time you don’t notice it.
When the car is in a higher gear and under load with the revs kept low (1800rpm or below) you can feel a hesitation from the car. Probably best compared to a stutter. If you accelerate through it and get the revs over 1800rpm it clears instantly. If you paddle the car down a gear and get the revs up it clears instantly. If you’re pushing on a bit so the car keeps itself in a lower gear with the revs being a bit higher it doesn’t happen.
I’ve checked the fault codes several times and there are no codes logged. I’ve driven the car with SDD connected and it’s not logging any misfires.
Tonight whilst the car was in the workshop I put the ignition on, wedged the throttle wide open and then smoke tested the car via the intake at 20PSI and can’t find any smoke escaping from anywhere either.
Has anybody got any suggestions as to what might be causing it? I was kinda hoping it would be a vacuum leak or something easy to fix but it doesn’t look like it. The car idles beautifully, sits on cruise control on the motorway smooth as silk and goes like a stabbed rat when you boot it so I’m absolutely certain that it’s not a fault with the timing.
Thanks,
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #676273 23rd Oct 2023 9:58pm
It made no difference I could tell but worth checking this pipe....
https://www.fullfatrr.com/forum/topic58105.html
Thumbs Up Pete
Post #676275 23rd Oct 2023 10:12pm
dhallworth
Cheers Pete.
That one is a right pain in the backside to get back on. It is sealing though as when I removed it tonight during the smoke test I was getting smoke out of it. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #676276 23rd Oct 2023 10:13pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Hi David,
A few thoughts,
Have had a similar issue on different vehicles and the solution has been to clean the throttle body.
Be very gentle when opening them manually ie against the motor as they can be easily damaged. Pay particular attention to the area around the disk and housing in the closed postion and edge of the disk flap as obviously this is where they can stick.
Another thought would be the airpath routine on sdd which the sdv6/8 have but unsure on 5.0?
Last one is maybe gearbox torque converter locking/unlocking?
Great work and always interesting Thumbs Up
Post #676286 24th Oct 2023 8:01am
dingg1
Look at misfire counters being logged on the iid tool, coil pack on its way out imo at certain conditions
Good luck
Post #676287 24th Oct 2023 8:40am
dingg1
Ah only skip read. Didn't see you had looked at misfires, can't edit on phone.
Still reckon it could be a dodgy coil pack though....
Post #676288 24th Oct 2023 8:43am
dhallworth
I’ve cleaned both MAF sensors and the throttle body this evening. Starting with the simple things first.
Situation normal for a 5.0 SC… the fuel light is on! I’ll take it for a run later on and see if it makes much difference.
Post #676321 24th Oct 2023 4:32pm
dhallworth
I’ve just driven from home to Costco. All the way to the Kingston Bridge (18 miles) the car was absolutely perfect. Crossed the flyover at the airport in 6th gear at 1200rpm up the slope with no tugs or hesitation so I was quietly confident that it was fixed.
We got stuck in traffic on the Kingston Bridge due to the roadworks and by the time we started to accelerate gently I could feel the hesitation was back.
I need to update the firmware on my IID tool this evening as it’s not reliably reading the live data and the SDD laptop balancing on the seat is nowhere near as convenient.
Post #676414 25th Oct 2023 1:14pm
JayGee
I'd suspect the coil pack if it's misfiring after being stuck in traffic and it's got hot. This is going way back but on software monitoring for another car I had it was possible to record ignition misfire events but not sure if the GAP IID tool can do this? 2012 TDV8 Vogue (L322)
Post #676423 25th Oct 2023 2:16pm
dhallworth
Managed to sort my IID tool out today.
Patrick at GAP sent me a firmware update for the IID tool which in turn flashed the engine ECU and then I was able to monitor all the live values perfectly.
I monitored the misfire counter all the way from Aberfoyle to home today (29 miles) and there were no catalyst damaging or emissions related misfires logged.
Climbing the lane to the farm shows this hesitation at its worst so I then started to monitor the readings coming from the MAF sensors and both were very similar to each other.
I then looked at the fuel trims and believe I’ve found the cause. I think I was on the right track with a vacuum leak so need to smoke test the car again when it’s hot. If that doesn’t reveal anything then it might be time to have a look at replacing the oxygen sensors.
The engine ECU was flashed when we were in Aberfoyle so the adaptions were reset. This screenshot was then taken 29 miles later with the car idling on the driveway.
Post #676453 25th Oct 2023 7:47pm
dhallworth
Popped in to see the local JLR specialist today. Explained what was going on with the car, explained that there were no misfires, both MAF sensors were giving very similar readings and that the fuel trims were off from where I'd expect them to be.
He said that in his experience when they have a vacuum leak they usually throw the engine management light on pretty quickly due to the mixture being lean.
It's booked in for a high pressure smoke test on 15th November (soonest they could do) and if I find anything and cure in the meantime I've to let them know. I said I was pondering it being a lazy oxygen sensor pulling the mixture away from where it should be and he said that was a good shout and could be a possibility.
There's someone on eBay selling genuine LR oxygen sensors for a good price so I'm tempted to change the 2 front pre-cat oxygen sensors just to rule them out before it goes to him.
Post #676492 26th Oct 2023 12:42pm
Yep, those fuel trims are way out if you reset adaptions 29 miles before, it only takes a short drive for them to stabilise, and I agree an air leak is the likeliest as they are positive numbers....
Good idea to change the oxygen sensors, one less thing to worry about...
Have you checked the fuel pressure, that pair of high pressure pumps on the 5.0 are known to suffer and give problems and it's a free check with an IID..!! Pete
Post #676496 26th Oct 2023 2:19pm
dhallworth
I’ve not checked the fuel pressure actually. It doesn’t give any issues when under wide open throttle and using full power so I assumed they were ok.
Do you know what the fuel pressure should be?
Thanks
Post #676503 26th Oct 2023 4:41pm
The IID says what is being called for and the sensors tell you what it's getting, so a quick, easy check... Thumbs Up Pete
Post #676512 26th Oct 2023 6:56pm
dhallworth
Had a quick peek tonight at the fuel pressure.
At 70mph on cruise control on the motorway:
On overrun coming down a slop road:
They look ok to me.
Post #676521 26th Oct 2023 7:43pm
