![]() | Home > Technical (L405) > Heated windscreen fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35592 ![]() ![]() |
the smaller plug is for the element that warms up the wipers..unless you have this feature then there will be no power from this plug..
Nonterraquous Member Since: 16 Apr 2023 Location: Fife, Scotland Posts: 9 ![]() ![]() ![]() |
Thanks for that Stan, and for the link to the workshop manual! |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
I have checked mine also. My nearside does not work. The violet cable is connected to the windscreen ribbon and the blue one is disconnected. I checked the voltage and cn't get a sensible reading from either. As there is only a single relay, I assume the windscreen or the cabling from the relay to the windscreen is damaged. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4 2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4 2002 4.4 Vogue 2000 4.6 Vogue 2010 Freelander 2 TD4 HSE 2009 Freelander 2 TD4.e 2009 1992 Mercedes 300D 1986 Renault 2.1 Turbo D 1976 Morris Marina 1.8 |
