Home > Technical (L460) > l460 V8 4.4 first service mileage
Amazing
so having only done 700 kms in the new car was a bit surprised to see a message that service was required in 1000kms pop up...only bought it in June.
when did yours pop up?
I guess its adaptive. it is better to have and not need then need and not have
Post #676022 21st Oct 2023 6:39am
Amazing
data protection
seems no one wants to share such sensitive data
here is screen shot
less than 1000kms half way through third tank full and service due in 200kms. Shocked .
so basically one service every 4 fill ups.
thats one hell of a tank fill to service ratio. fuel use settled at12mpg.
anyone worse?
Post #676572 27th Oct 2023 10:01am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I think no one knows the answer, clearly wrong, suggest you talk to the dealer. letters not necessarily in the right order
Post #676573 27th Oct 2023 10:11am
Amazing
no body knows
my point was to establish a first service mileage estimate to avoid the dealer using the "they are all like that" response, which for many is a key function of forums to provide information. Shame that no one wished to share. it is better to have and not need then need and not have
Post #676687 28th Oct 2023 2:45am
Kot
First off all fill in your profile.
There are not to be many members on here with your top of the range engine L460, and if they did, 1st port of call is the dealer. I cant understand why you would trawl the internet
I see you say it's a V8 so it can only be the Petrol P530, why did I need to search this? You should provide these details.
Good luck with your talk with the dealer, its your best course off action, you have warranty use it!
If its not as per advertised REJECT it. 2018 SE SDV8 4.4 Byron Blue
Post #676695 28th Oct 2023 9:34am
