Home > Maintenance & Mods (L405) > FBH and lots of smoke !
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Hi, this may be a common issue ?? I turned on the FBH this morning for the first time in a long time, a few minutes later there were clouds of diesel smoke everywhere ! Bit scary actually, whats the issue ? Is it a DIY fix or off to the garage ? Thanks folks
Post #675574 15th Oct 2023 10:15am
Phoenix
May well be 'old' diesel in the pipe, did you turn it off or did it clear after a while?
It may well need a new nozzle/burner assembly, they do corrode. The last one I did cost ~£80 for the parts but well worth it for the effect it has when working properly.
Post #675577 15th Oct 2023 11:15am
Ragingrover
Thanks for the advice. I turned it off straight away but thought about terying it again later. It was a shock to the system at the time !
Post #675578 15th Oct 2023 11:30am
Phoenix
If it doesn't clear within 2-3 mins, I'd suggest turning it off and having it looked at - are you sure it was diesel smoke & not just water vapour? they can belt out a fair bit of water vapour drying out the combustion chamber, exhaust & silencer. There must have been combustion detected for it to keep going and not shutdown by itself.
Post #675579 15th Oct 2023 11:37am
Ragingrover
It was unburnt diesel alright, stank to high heavans and was thinking the neighbours would call the fire brigade ! lol
Post #675595 15th Oct 2023 6:24pm
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
My L322 did this when I first had it, I was cleaning it and temp was low. I had to move the car to let a friend out the drive and when I shut it off smoke everywhere I thought it was on fire!!
Luckily a few proper journeys and it was fine, never was an issue again
Post #676354 24th Oct 2023 7:35pm
RiverBlanche
Hi
the FBH is a bit like any other engine, they like to have a good run up to temp, constant short starts/trips and they start up but don't get up to temp and shut off again, like other diesel engines let them get up to temp.
Post #676502 26th Oct 2023 4:20pm
kevinp
My car still randomly smokes from the FBH. It's exhaust pipe gets very hot when it does work.
I've read lots about stripping the combustion chamber to remove the carbon build up and how the glow plug gets stuck etc.
Has anyone tried one of these service kits?
Post #683201 19th Jan 2024 2:03pm
