![]() | Home > In Car Electronics (L405) > DAB Query |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 ![]() ![]() |
what solved my problem was a bead of black mastic around the base of the DAB antenna on the roof..
The DAB uses a diversity antenna system, one is in the roof pod, the other is a flat plate in the OS of the spoiler with a signal splitter /amplifier, the splitter / amplifier relies on an aluminium bracket bolted to the OS liftgate hinge to get it's ground plane, I've seen several of these corroded enough under the nut head to give a resistive connection and therefore a poor ground plane. Or it could be the roof pod (or receiver / wiring issue) I'd recommend having a look at DTC's to determine the area of concern before you start pulling things to bits. |
Garfy Member Since: 01 Oct 2023 Location: Sussex Posts: 4 ![]() ![]() ![]() |
thanks stan ![]() |
thanks phoenix ![]() |
Its easy enough, but you need somewhere that understands radio, unless they have a RF spectrum analyser (instantly sounds expensive but a decent one can be had for £130) then they'll most likely just be playing parts darts - with your money. |
