Home > In Car Electronics (L405) > DAB Query |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
what solved my problem was a bead of black mastic around the base of the DAB antenna on the roof..
7th Oct 2023 7:41am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The DAB uses a diversity antenna system, one is in the roof pod, the other is a flat plate in the OS of the spoiler with a signal splitter /amplifier, the splitter / amplifier relies on an aluminium bracket bolted to the OS liftgate hinge to get it's ground plane, I've seen several of these corroded enough under the nut head to give a resistive connection and therefore a poor ground plane. Or it could be the roof pod (or receiver / wiring issue) I'd recommend having a look at DTC's to determine the area of concern before you start pulling things to bits. |
7th Oct 2023 8:56am |
Garfy Member Since: 01 Oct 2023 Location: Sussex Posts: 4 |
thanks stan |
8th Oct 2023 2:08pm |
thanks phoenix not sure i understood some of it (lol), but very much appreciate the response. i think i'll need to take it somewhere, but was concerned they'd spend 3 weeks looking for it, at least i can advise from your comments. |
8th Oct 2023 2:10pm |
Its easy enough, but you need somewhere that understands radio, unless they have a RF spectrum analyser (instantly sounds expensive but a decent one can be had for £130) then they'll most likely just be playing parts darts - with your money. |
9th Oct 2023 3:22pm |
