Home > Technical (L460) > Throttle response
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Throttle response
I am unhappy with the throttle response on my p530.
Is anyone else having problems.
If you want to pull off from stationary it is not linear or consistent or predictable.
It can be laggy or brutally unsubtle. letters not necessarily in the right order
Post #674854 4th Oct 2023 9:15am
5.0
I wouldn’t say mine is laggy like the L405 was and I wouldn’t call it unpredictable because it has a consistent action. But, the transmission or accelerator does have a strange software setup. When driving gently all is well, but call for a little more from the accelerator and you get a lot more than you were expecting. In this respect I would agree that it seems non linear. I can’t tell for sure if the transmission is dropping a gear when it does this and that’s what’s causing it. It is certainly overly aggressive in the non dynamic setting. I don’t expect any software updates to address this now though given the P530 engine has been updated.
Post #674941 5th Oct 2023 2:20pm
orbtar
England 2015 Range Rover Vogue SE SDV8 Santorini Black
Re: Throttle response
I agree with this, it makes parking it in small spaces quite awkward as it either doesn't move or suddenly lurches forward. My wife doesn't like driving it as the throttle is so unpredictable. 2015 RR SDV8 Vogue SE
2014 RR Sport Dynamic
1952 Jaguar XK120 Roadster
Post #679203 1st Dec 2023 10:53am
Dixy
The car is in at present. Very good response from the service team, had feared they might say yes sir they all do that.
They sent a technician out with me who understood what I was not happy with and will check for fault codes and if none feed back to JLR Engineering.
It may take a little time but if you have a newly launched model then you should accept some Beta testing.
Please if anyone else has this then do take it in and get it fed back to JLR. letters not necessarily in the right order
Post #679414 4th Dec 2023 1:14pm
orbtar
Mine is in for first service on Friday so will ask them to look into it. 2015 RR SDV8 Vogue SE
Post #679415 4th Dec 2023 1:17pm
Dixy
Well they had it 3 further times and eventually said it was a characteristic of the car.
Had pretty well decided to cut my losses and order a Bentayga.
At the weekend a SOTA appeared
Downloaded yesterday and had a 30 mile run in it today, don't want to count chickens but it feels good.
When I ordered a new launch model I accepted there would be some beta testing but expected the dealers to at least listen and feed back to the factory. letters not necessarily in the right order
Post #692532 13th May 2024 5:24pm
Dixy
Well that was a pleasant surprise, so much better, in fact I am feeling some love for the car. letters not necessarily in the right order
Post #692682 15th May 2024 8:52am
