![]() | Home > General (L405) > Easy Exit/Entry options? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1408 ![]() ![]() |
Have your normal driving position stored as memory 1, then same seat position and steering whee full up stored as 2. The when you open the door, press 2, climb in, press 1 and start and away you go ? V8 or else ... |
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 59 ![]() ![]() ![]() |
Check what position your Steering Adjuster is in? If it’s on Auto then twist it too Off.
