Home > Maintenance & Mods (L322) > Philips RacingVision GT200 H7 Halogen 55W Bulbs
pcourtney
Have been told to get these as replacement H7 halogen bulbs, other options I should look at ?
Philips RacingVision GT200 Racing Vision GT 200 Car Headlight Bulbs H7 (Twin)
Why buy Philips RacingVision GT200 H7 (Twin)?
Following on from Philips' legendary RacingVision range of car headlight bulbs, the RacingVision GT200 offers an even more powerful light projection, up to 200% brighter than a standard halogen bulb. This astonishing light output illuminates up to an extra 80 metres of the road, allowing you to drive comfortably and safely, with a heightened awareness of your surroundings at night.
The RacingVision GT200's intense light ensures up to 200% extra brightness thanks to Philips' superlative engineering know-how and experience in the automotive light industry. These Maximum Performance headlight bulbs are the highest performing halogen in the entire Philips portfolio.
Philips' patented gradient and screen-print coating techniques ensure a striking, crystal-clear projection, while their 'Diamond Precision quartz glass' guarantees accurate beam placement and sharp cut-off. This allows for both huge coverage of light on the road ahead and a strong defence against thermal shocks and extreme climates. And the Racing Vision GT 200 bulb's enhanced UV absorption protects your headlight optics, allowing for optimal light performance and a protected bulb lifespan.
The Philips RacingVision GT200 has been rigorously designed in adherence both to Philips' own meticulous quality control processes, and ECE homologation standards – it is completely road legal. So you can experience massively enhanced lighting and increased comfort and safety on any public road you like.
Features and benefits
Up to 200% brighter than standard halogen
See up to 80 metres farther than standard
Maximum Performance bulb
Quartz glass technology for precise light and enhanced durability
Resistant to thermal shock and extreme temperatures/weather
Philips' patented bulb coating for maximised light output
Road legal – ECE certified for use on public roads
Post #674544 29th Sep 2023 6:29pm
Ennoch
Two things;
1) I thought all 2011 FFRR's were xenon in main and dipped?
2) I've used many uprated bulbs over the years and generally find the latest, highest percentage extra OSRAM Nightbreaker option to be the longest lasting. Phillips bulbs are decent, but I never found the life of their uprated ones to match the OSRAM's. 55W is the 'standard'. These uprated bulbs are generally using different coatings, filaments and gas to maximise output for the same standard current draw. FWIW I run 100W bulbs in the Hella spots on the Impreza and they're only a tiny bit brighter than the 200% uprated 55W ones. With that though you need to have sufficient wiring to cope, I wouldn't run them in standard light units.
Post #674547 29th Sep 2023 7:13pm
JayGee
Dipped should be xeon's on that MY. I replaced the H7 main beam with LED's and they are significantly brighter ( turns an unlit country lane into daylight). All the dipped beam replacement bulbs seem to do is create a more concentrated patern which doesn't have any more total light output 2012 TDV8 Vogue (L322)
Post #674549 29th Sep 2023 7:30pm
pcourtney
Just looked in the User Manual and yes Low and High Beam are Xenon D3S - so not Halogen after all, blimey they are a few quid as well, £45 each
https://www.ebay.co.uk/itm/234371785802?ha...R_DExKjcYg
Post #674555 29th Sep 2023 9:05pm
mjdronfield
The main beam “spots” are halogen. You can change those, but main headlight is xenon as mentioned above.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #674556 29th Sep 2023 9:23pm
JayGee
These are what I fitted ( as suggested by MJDronfield) https://www.ebay.co.uk/itm/371786510808?mk...media=COPY 2012 TDV8 Vogue (L322)
Post #674570 30th Sep 2023 8:32am
