Home > Maintenance & Mods (L322) > NSF wheel bearing |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3142 |
You will need a press to remove and refit the bearing into the hub.
25th Sep 2023 10:38pm |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 92 |
Thank you for your reply, the more I read the more I see the overtime loomimg Borrowed Grey 2002 3d 204k for a year
26th Sep 2023 1:25am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 |
Maybe get another quote or two from some other independents in the area?? e.g. Henshall Engineering Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Sep 2023 7:07am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 456 |
im in the same boot |
26th Jan 2024 10:14pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 |
Although I have done this job on my driveway, I will admit that it was a pain to do, especially as I did not own a hydraulic press at the time. This is not a job for the faint hearted as there were several moments during said task.
27th Jan 2024 6:38am |
On a more serious note, looking at the age of your car, mine is a 2006, the deeper I got into the job, the more faults I found, and had to order more parts in a hurry, so if you do it yourself be prepared to have the car out of action for longer than intended. My car ended up on axle stands for a almost a week as I then had to wait for parts delivery etc |
27th Jan 2024 6:51am |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 185 |
There is also a fair chance the wheel speed sensor will have to be replaced, go genuine on that, aftermarket seem a bit hit and miss.
27th Jan 2024 10:52am |
GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 34 |
I bought a wheel speed sensor from Delphi with a green plug, it fit perfectly but was showing the wheel speed 2x higher than it was. It confused the whole ABS system. The plug on the car side was blue so I then bought a Bosch sensor with a blue plug and everything worked fine again. |
27th Jan 2024 11:42am |
