![]() | Home > Technical (L405) > Rear executive seats on Autobiography. |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1055 ![]() ![]() ![]() |
I don’t have the exec seats, but it might be a memory setting. Both front seats in may car have up to three settings and the drivers seat lowers and steering wheel rises each time you switch off and do the reverse when you start up. |
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 61 ![]() ![]() ![]() |
I’m not sure if it’s a setting that I am missing as ye you are right about the driver seat but not sure about the rear seats. Like I said if they are not fully reclined when the engine starts then they will recline fully every time you start engine. |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 513 ![]() ![]() ![]() |
mine don't recline as you describe, they stay in the last position First time FFRR owner |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1665 ![]() ![]() ![]() |
mine stay where they were too. It must be a seat memory setting thing. Do they 'go back' to vertical after you switch off? 405 AB exec seats Baltic and Cirrus
Ace171 Member Since: 05 Mar 2014 Location: Ringwood Posts: 1 ![]() ![]() ![]() |
I have the same issue as the original poster, my rear seats will recline automatically as i drive off even though I have moved them to upright and set M1 and will not return unless I press the memory button again, Anyone come to a conclusion? |
