Home > Technical (L405) > Rear executive seats on Autobiography.
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
Hi All,
Recent purchase of FFRR 2018 Autobiography.
Learning new things everyday about the car and features.
I have noticed that the rear Exec seats fully recline to max after few seconds when the engine is switched on?
Regardless of the position they are in…they will recline full after engine on…you can then manually adjust them to your requirements or use the preset memory buttons.
Just annoying…any help will be appreciated.
Post #673903 20th Sep 2023 12:36pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I don’t have the exec seats, but it might be a memory setting. Both front seats in may car have up to three settings and the drivers seat lowers and steering wheel rises each time you switch off and do the reverse when you start up.
Post #673930 20th Sep 2023 5:52pm
Maher2023
I’m not sure if it’s a setting that I am missing as ye you are right about the driver seat but not sure about the rear seats. Like I said if they are not fully reclined when the engine starts then they will recline fully every time you start engine.
Post #673933 20th Sep 2023 6:14pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
mine don't recline as you describe, they stay in the last position First time FFRR owner
Post #673934 20th Sep 2023 6:26pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
mine stay where they were too. It must be a seat memory setting thing. Do they 'go back' to vertical after you switch off? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #673936 20th Sep 2023 6:48pm
Ace171
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Rear Executive seats keep reclining
I have the same issue as the original poster, my rear seats will recline automatically as i drive off even though I have moved them to upright and set M1 and will not return unless I press the memory button again, Anyone come to a conclusion?
Post #711016 4th Feb 2025 1:16pm
