Home > Technical (L405) > Low battery start engine L405
stop/start is very easy to switch off permanently... Thumbs Up ... - .- -.
Post #675847 18th Oct 2023 8:20pm
caymanblack
How Stan? thx.I never want to use it. overfinch modified
Post #675852 18th Oct 2023 10:22pm
Vogue
On my last L405, you could disconnect it by removing the negative off the stop start battery. The only issue was I also lost the heated seat function - all ok in the summer, but when you want heated seats in the winter it wasn’t much fun 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #675859 19th Oct 2023 8:33am
as above if you have an aux battery in the rear cubby or disconnect the signal wire if you have a condenser.
https://www.fullfatrr.com/forum/topic52063...p;start=15
mines been disconnected for many years and all my stuff works.. ... - .- -.
Post #675861 19th Oct 2023 8:49am
Phoenix
I'd have thought that just disconnecting the BMS on the aux. battery would disable Autostop, it does on a lot of other marques.
Post #675875 19th Oct 2023 11:38am
