![]() | Home > Technical (L405) > Low battery start engine L405 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
stop/start is very easy to switch off permanently... |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1156 ![]() ![]() ![]() |
How Stan? thx.I never want to use it. overfinch modified |
as above if you have an aux battery in the rear cubby or disconnect the signal wire if you have a condenser.
I'd have thought that just disconnecting the BMS on the aux. battery would disable Autostop, it does on a lot of other marques. |
