Home > Technical (L405) > L405 4.4 Diesel Replaced Failed Engine Oil Sensor but still
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
So, I wanted to check the oil and just kept getting the 'Unavailable' message. Plugged in a scanner and I had various codes show up (no dashboard lights) all pointing to failed oil level sensor. I have 2 different garages diagnose the codes and both came to the conclusion that the oil level / temperature sensor needed replacing. I went to the second garage only because the first one that did the diagnosis wanted to take the engine out to replace the sensor instead of risking shearing any of the bolts in the subframe. The second garage have replaced the sensor successfully without taking the engine out BUT despite clearing the codes they still immediately return still cannot view oil level. So far this is sitting at a £1600+ oil change as that is the only thing that appears to have changed. I noticed that a couple of codes seem to mention the fan and also front vent something or other so I am wondering if they and the oil sensor are part of the same wiring loom? Anybody any ideas what else to look at? I am already stuck with having to pay a further £99 per hour labour charge whilst the garage chase blind through the wiring looking for any problem and also have £200+ software update booked in for tomorrow. I have some warranty cover for this but they are only to pay the RR quoted book labour hours of 6.5 which doesn't even cover half of this cost. I have the only been the very disillusioned owner of this vehicle for 2 months and wish I had never bothered trying to check the oil as without any dash lights I wouldn't have been any wiser and I dont see what detrimental effect not having a working oil sensor could have other than not knowing how much oil is in the engine or am i wrong?
Any pointers would be greatly appreciated!
Many thanks in advance
Post #673282 13th Sep 2023 2:04pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
This might not be what you want to hear, but my oil sensor has never worked since I bought the car 3 and a bit years ago.
I looked into getting the sensor replaced, although just couldn't justify the cost. So went for the guitar string option for £5, which works perfectly well for measuring oil level - as long as you leave the car long enough for the oil to settle properly.
More information here:
www.fullfatrr.com/forum/topic56693.html Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #673286 13th Sep 2023 3:19pm
ReggieMac
So does it not make any difference to the vehicle that it doesn't work? Does not affect emissions or anything else?
Post #673291 13th Sep 2023 3:50pm
Kot
Re: L405 4.4 Diesel Replaced Failed Engine Oil Sensor but st
I had issues with my level sensor a couple of years ago, it wouldn't show even after the work around--
"Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake).
Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows!
Code check showed P250B-29, P250B-87 Engine oil level sensor - circuit range/performance
P0196-29 Permanent Engine oil temperature sensor circuit range/performance.
I had oil tracking in the sensor loom, believe it comes from turbo actuator which had been replaced previously. Have you inspected/change the loom mentioned in N375?
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf 2018 SE SDV8 4.4 Byron Blue
Post #673309 13th Sep 2023 7:31pm
ReggieMac
I will ask the garage about N357 and I would have hoped that they would have checked this already (?) Neutral but you never know!
Post #673330 14th Sep 2023 7:51am
Zebedee
The only think that seems not to work properly is the service interval calculation. I get a message about every 4k saying service required and my indie thinks this is because the oil level is used in the calculation for oil dilution. With no oil level, the service interval defaults to needing doing every 4k. So I change oil every other notification - i.e. every 8k.
Everything like DPF regens work fine and no other issue has shown its face. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #673363 14th Sep 2023 5:21pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
The oil actually tracks up from the level sensor, usually due to the wires in the sump having heat damaged insulation, this can then track through the engine loom to the turbo actuator eventually causing failure of same. Campaign N357 attempts to stop this with the additional loom.
Post #673371 14th Sep 2023 7:20pm
Kot
Interesting
as I had the Turbo actuator replaced under warranty april 21. Then 4 months later oil sensor packed in-- again fixed under warranty at MD never got a straight answer what the fault was but they certainly didn't have it long enough to change it out, so wonder did they change the loom after the TA was replaced under 375? or when I complain oil level was not working ?
that was August 21 no further faults with oil sensor.
Or maybe the appo forgot to connect it back up again Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #673419 15th Sep 2023 1:20pm
caymanblack
Mine has had the loom replacement but at last service I was told there was oil in the plug does this mean I should get it changed again? overfinch modified
Post #673484 16th Sep 2023 8:58am
Zebedee
All the N357 extra wiring loom does is put an extra bit of wiring and another plug between the oil sensor and the rest of the wiring - it is a sticky plaster at best.
The real issue is the appaling design where someone decided it would be a good idea to mount the sensor internally in this engine, when the part is designed to be mounted externally [and would be easy to change when it fails - such as on the L322 using the 4.4TDV8]. It fails because oil gets into the sensor/wiring and tracks back up into the wiring loom.
Read more about it here: www.fullfatrr.com/forum/topic56693.html Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #673677 18th Sep 2023 10:35am
ReggieMac
Certainly agree with the poor design. But anyway, I suppose as it is done now I can only hope it lasts but at least I know better if it goes again! Incidentally, would you expect there to be the smell of oil fumes in the cabin whilst driving after having this job done? I initially assumed it is spilt oil burning off from the exhaust but I have done a couple of hundred miles now and I still have this smell, it wasn't there before having the sensor replaced (I am not for one moment suggesting that it is the sensor at fault).
Post #673932 20th Sep 2023 5:10pm
caymanblack
let's hope its all ok now and clears. did they renew the loom again also? overfinch modified
Post #673955 21st Sep 2023 8:21am
ReggieMac
Yes the wiring loom was replaced as well. There were a whole list of parts replaced, seals etc, and it was a 2 page invoice detailing diagnostics and parts used so pretty through (bloody should be for what it cost!). I really hope the cabin smell dissipates soon though else I may have to go back!
Post #673960 21st Sep 2023 9:06am
