Home > Technical (L405) > L405 4.4 Diesel Replaced Failed Engine Oil Sensor but still |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 377 |
This might not be what you want to hear, but my oil sensor has never worked since I bought the car 3 and a bit years ago.
13th Sep 2023 3:19pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 183 |
So does it not make any difference to the vehicle that it doesn't work? Does not affect emissions or anything else? |
13th Sep 2023 3:50pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1195 |
I had issues with my level sensor a couple of years ago, it wouldn't show even after the work around-- "Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake). Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows! Code check showed P250B-29, P250B-87 Engine oil level sensor - circuit range/performance P0196-29 Permanent Engine oil temperature sensor circuit range/performance. I had oil tracking in the sensor loom, believe it comes from turbo actuator which had been replaced previously. Have you inspected/change the loom mentioned in N375? https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf 2018 SE SDV8 4.4 Byron Blue |
13th Sep 2023 7:31pm |
I will ask the garage about N357 and I would have hoped that they would have checked this already (?) but you never know! |
14th Sep 2023 7:51am |
The only think that seems not to work properly is the service interval calculation. I get a message about every 4k saying service required and my indie thinks this is because the oil level is used in the calculation for oil dilution. With no oil level, the service interval defaults to needing doing every 4k. So I change oil every other notification - i.e. every 8k. Everything like DPF regens work fine and no other issue has shown its face. Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
14th Sep 2023 5:21pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 224 |
The oil actually tracks up from the level sensor, usually due to the wires in the sump having heat damaged insulation, this can then track through the engine loom to the turbo actuator eventually causing failure of same. Campaign N357 attempts to stop this with the additional loom. |
14th Sep 2023 7:20pm |
Interesting
15th Sep 2023 1:20pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1130 |
Mine has had the loom replacement but at last service I was told there was oil in the plug does this mean I should get it changed again? overfinch modified |
16th Sep 2023 8:58am |
All the N357 extra wiring loom does is put an extra bit of wiring and another plug between the oil sensor and the rest of the wiring - it is a sticky plaster at best.
18th Sep 2023 10:35am |
Certainly agree with the poor design. But anyway, I suppose as it is done now I can only hope it lasts but at least I know better if it goes again! Incidentally, would you expect there to be the smell of oil fumes in the cabin whilst driving after having this job done? I initially assumed it is spilt oil burning off from the exhaust but I have done a couple of hundred miles now and I still have this smell, it wasn't there before having the sensor replaced (I am not for one moment suggesting that it is the sensor at fault). |
20th Sep 2023 5:10pm |
let's hope its all ok now and clears. did they renew the loom again also? overfinch modified |
21st Sep 2023 8:21am |
Yes the wiring loom was replaced as well. There were a whole list of parts replaced, seals etc, and it was a 2 page invoice detailing diagnostics and parts used so pretty through (bloody should be for what it cost!). I really hope the cabin smell dissipates soon though else I may have to go back! |
21st Sep 2023 9:06am |
