Home > Maintenance & Mods (L405) > Headlight alignment.
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
I think that my headlights are too high. I’ve learned about the adjuster. Is there one on each side ?
How do I determine the correct height for my dipped beam please. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #673190 12th Sep 2023 9:27am
Gremlin500
I think Stan can help here, there are adjusters both sides, Stan posted on this a while back with a pic but I can’t find it Embarassed
Be aware if you dip the beams too much, you may be disappointed in how far you can see with regular bulbs, L405 lights are not the best, maybe time for an upgrade? Twisted Evil “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #673197 12th Sep 2023 10:35am
GrandadRob
Thanks for that.
What does an upgrade provide, is it easy to fit. 2013 SDV8 4.4 SE Luxor.
Post #673200 12th Sep 2023 10:53am
i couldnt find the post either Phil.. Laughing
so , this is from the workshop manual..[which everyone should download Wink ]
Post #673203 12th Sep 2023 11:22am
Gremlin500
@GrandadRob:
Search “D3S” on here (hint: it’s not a Citroen Rolling with laughter ) and also Google it, there’s a plethora of stuff to read!
Fortunately, on the TDV6 it’s a relatively easy 30-minute job, since the rear of one headlamp has free access (drivers side) and the other just needs the airbox and hoses loosened and moved out of the way to make some space to get your hand in, it’s just a screwdriver job, really.
I went for the Osram Nightbreaker uprated HID bulbs, which have recently been further enhanced.
Now of course, there are also high-output LED bulbs, but you need to read up on the pros & cons before deciding. Lots of spurious claims about millions of lumens from equally spurious sellers, caveat emptor!
Good time to do it, the nights are cutting in fast! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #673213 12th Sep 2023 12:25pm
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
I downloaded the workshop manual - thanks for the tip. But I must say the information on adjusting the headlights is fantastically scant. It doesn't mention which hex screw is for up/down or what size it is. However, I think I have worked this out from watching Youtube.
Post #674101 23rd Sep 2023 6:55pm
