Home > Technical (L322) > Cutting Out Quandry 4.4 TDV8
General
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
I have a 2012 Westminster and it has cut out 2 or 3 times when pulling away from junctions,fault code was B1140-15 Engine Crank Authorisation.
Possible causes
Engine crank authorisation signal circuit short circuit to power or open circuit.
Actions required
Refer to the electrical circuit diagrams and check engine crank authorisation signal
I was going to replace the crank position sensor,do you think this is the best course of action?
If so does anyone know how you get to the sensor?
Looking at engine diagrams it looks like it is behind the starter motor.
Thanks in advance for any help or advice. Very Happy
Post #673077 10th Sep 2023 12:03pm
DrRob
Also check any pending codes logged on the IID. They sometimes help further diagnose issues Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #673078 10th Sep 2023 12:13pm
Baltic Blue
It’s fully detailed in the W.M.
Mike
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #673083 10th Sep 2023 1:34pm
