Cutting Out Quandry 4.4 TDV8 | |
I have a 2012 Westminster and it has cut out 2 or 3 times when pulling away from junctions,fault code was B1140-15 Engine Crank Authorisation.
Possible causes
Engine crank authorisation signal circuit short circuit to power or open circuit.
Actions required
Refer to the electrical circuit diagrams and check engine crank authorisation signal
I was going to replace the crank position sensor,do you think this is the best course of action?
If so does anyone know how you get to the sensor?
Looking at engine diagrams it looks like it is behind the starter motor.
Thanks in advance for any help or advice.
