Home > Maintenance & Mods (L322) > Front shocks and Height sensors |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
The general consensus on here is to stick with original LR height sensors. No issues then.
8th Sep 2023 6:27pm |
Bristol RR Member Since: 20 May 2023 Location: Bath Posts: 20 |
I was hoping the height sesnsors would be made by someone else rather than britpart… I’m spending serious cash in the car as it has unknown history so don’t want to skimp but also don’t want to fit britpart. I’ll have a look for the gen ones.
8th Sep 2023 6:40pm |
Get in touch with Duckworths on here, site sponsors. A good price and free delivery. Can sometimes offer non gen stuff too.
8th Sep 2023 7:36pm |
Yes will do. For shocks though they are £1400 each new so even with forum discount they are bloody expensive. You could swap out 3 she’s of arrosus for that price!!
8th Sep 2023 7:42pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 761 |
BWI shocks (VCD for 2012 Westie) available from Island 4x4 at under £1000 for the pair. The older I get, the more I realise that people confuse wrinkles for wisdom |
8th Sep 2023 9:09pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2515 |
I'm curious as to why you think that the height sensors should be replaced.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Advanced Factors have BWI at affordable prices for the earlier cars, but Macpherson only for the later cars: https://www.advancedfactors.co.uk/front-ai...-292-c.asp 2015 Range Rover Autobiography 4.4 SDV8 |
8th Sep 2023 9:37pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
At only 56k the height sensors should not need replacing but neither should the shocks or airbags. Mine are still functioning properly with more than 100k more than yours on them. Is the leak on the front shock oil or air and if it's 'crashing' over bumps this may not be shock related. 2012 TDV8 Vogue (L322) |
9th Sep 2023 7:27am |
Changed the front brakes and discs a week ago. Massive oil leak coming from passenger shock and bounces all over the place, very little damping. Drivers side seems ok but I’d always replace in pairs like brakes.
9th Sep 2023 10:03am |
It's had a very hard life in those 56k miles then. What are the upper and lower suspension arms joints and bushes like as theses are common fail items after heavy use/ high miles. 2012 TDV8 Vogue (L322) |
9th Sep 2023 10:13am |
Jaygee,
9th Sep 2023 12:26pm |
