Home > Technical (L405) > Deployable steps reset
supershuttle
I’ve read quite a bit on here about maintaining the steps but my problem is slightly different on unlocking the car both steps deploy normally. However on opening the passenger door step comes out but immediately goes back in. I wouldn’t have noticed but SWMBO makes a bit of a fuss, can they be reset? Geoff
Post #672326 30th Aug 2023 2:33pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
This is worth a try, as it comes out, stand on it and lock the doors. This should cause it to stay out. Then unlock & lock and it (should) reset 2017 (67) Vogue SE Corinthian Grey
Post #672336 30th Aug 2023 5:16pm
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Alternatively, there is a reset button. Sit in the drivers seat. In front of your right knee is a switch panel with two switches. One opens the tailgate, the other resets the steps. Just hold the steps button in for 10 seconds. It might work. My one needs resetting if I have gone over serious potholes. It thinks I’ve been off roading. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #672347 30th Aug 2023 6:34pm
Abacus405
No such button in mine (‘17 model’) 2017 (67) Vogue SE Corinthian Grey
Post #672348 30th Aug 2023 6:37pm
supershuttle
Well I've never noticed that button before but it does seem to have done the trick - thanks. Geoff
Post #672382 30th Aug 2023 11:25pm
How have you never noticed that button Geoff? How do you open your boot lid for the wife?
Post #672385 30th Aug 2023 11:46pm
supershuttle
Ive only had the car a few years, always nice to discover something new - anyway it didn't work. Geoff
Post #672422 31st Aug 2023 1:19pm
caymanblack
17 model the steps are turned on/off from the main screen menu.
I turn mine off when just pulling the car in and out of the garage and messing around with it and reactivated them when I go on a journey. overfinch modified
Post #672449 31st Aug 2023 6:31pm
