Home > Technical (L322) > access mode
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
99% of time I forget to press acess mode button anyway.
Auto mode will not help. Lowering takes time, but usualy when the engine is stopt, you (or passanger) will immidietly open the door.
So I use this mode only when washing the car. Better acess to the bonnet and glass.
Post #672558 2nd Sep 2023 3:49pm
Weegie
I always lower when coming to a stop except when it is getting washed as I see it as giving better access to the wheel arches etc to get rid of any crud or mud. John
GAP iiD BT
Post #672560 2nd Sep 2023 4:13pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Always drop to access mode, just before stopping & as Kevinp stated.
Post #672562 2nd Sep 2023 4:50pm
Rambles
Am not sure if this is as designed
But i when i have exited my FF, having parked in access mode…and double lock the RR, a few seconds later the car settles EVEN lower, and I hear the compressed air coming out of the system.
Do other folks get the same ?
When left over night, it takes a few seconds for the compressor to re-pressurise the system and lift the RR back into normal.
Post #672611 3rd Sep 2023 8:14am
If you are not parked on level ground then the fatty will try to level itself after being parked, it does it by dropping the high corners, it doesn't add any air....
If yours is taking time to react on start up then I would suggest there is some reason air is exciting the system and it's low or empty when you restart...
Maybe worth some investigation.... Thumbs Up Pete
Post #672613 3rd Sep 2023 8:18am
Phoenix
The self levelling after exit is normal, after all, you've just removed several tens of kilos from the vehicle so it will rise from it's previous height as you get out.
If the air reservoir is depleting overnight, that is not correct and requires investigation.
Post #672614 3rd Sep 2023 8:24am
DrRob
Lower mine with the door button every time. Press it as you’re slowing down to stop. Will be done by the time you stop and before any door openings. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #672625 3rd Sep 2023 10:03am
landy95
I wonder how dropping into access mode and leaving for excessive time affects the suspension bushes as when they are fitted they are locked in place when at normal height so no load. I guess sitting at access height with a torsional load on them must reduce their life. Just a thought. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned 1991 Range Rover Vogue 3.9 V8.
Post #672652 3rd Sep 2023 9:31pm
Rambles
Self levelling would be it! I park on a reasonable slope
Post #672660 4th Sep 2023 5:27am
