![]() | Home > Maintenance & Mods (L405) > 2017 L405 ACE Drop Links/ARB Bushes |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 708 ![]() ![]() |
The links themselves are common between cars with/without ACE.
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 233 ![]() ![]() |
The bushes for the ACE equipped vehicles are different - MY18-on are also slightly different again.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1797 ![]() ![]() |
Been there, done that. Not fun |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 226 ![]() ![]() ![]() |
That's great thanks chaps!
All fitted - knocking gone and a huge improvement on the drive! Thanks all |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
Did you do the rear?
Used aftermarket, these are fairly common on RR’s and basic tech, so I didn’t see the need for the added OEM expense.
Thank you. I replaced my fronts previously with Mevotech. The “may” be part of the knock return. I will try Delphi next front and rear. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
Think Delphi are a decent brand for this application. If you can get Febi Bilstein in CA then so far so good! |
I had trouble getting the previous ones to torque. I had to use vice grips on the backside collar to reach 185nM. Maybe the Delphi will be better and won’t spin all the way to torque. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
Word of warning if anyone finds this via search.
Bagus Member Since: 14 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
How stiff were the LR drop links? I’ve bought a set and the ball joints are very easy to move around with one hand but was expecting them to be very stiff. 2016 5.0 Loire Blue
Jaws_RR Member Since: 28 Feb 2025 Location: Harrow, Greater London. Posts: 2 ![]() ![]() |
Hi, I just bought my first Range Rover and am in the middle of renewing the suspension. Previous owner ran it on a shoestring. Do I need new brackets and bolts or can I just replace the rubber D bushes? Thanks. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8455 ![]() ![]() ![]() |
If you are talking about ARB mounting bushes then you can reuse if they are not badly rusted and weakened.. the original bushes are stuck to the bar so you have to cut it all off...
