Home > Technical (L405) > Dead engine need to raise suspension
Hodgey26
Australia 2004 Range Rover HSE Td6 Adriatic Blue
Hi Does anyone know how to raise the suspension without the engine running? My 4.4SDV8 has died and its been sitting a while in the garage waiting for me to get to it to start diagnosing the engine failure. the airbags have slowly leaked and its now on the bump stops and I want to put it on a car trailer to move to the workshop. When i turn the key on and try to raise the suspension it says "start engine to raise suspension" I am hoping there is a way to bypass this some how??
Post #671738 22nd Aug 2023 9:25am
Martyn
2013 Range Rover Vogue SE SDV8 Aintree Green
Turn the ignition on, no engine running, put the hazzard lights on and close the door, you can then hold the lights and unlock button on the keyfob to raise the suspension (providing there is enough air in the tank).
I used this method a few days ago after my engine failed. 2013 FFRR Vogue SE
Post #671770 22nd Aug 2023 4:10pm
Hodgey26
Thank you so much Martyn, this worked perfectly!! now to find out what has happened to this engine cheers Thumbs Up
Post #671809 22nd Aug 2023 11:02pm
