Home > General (L405) > 3.0SC. What do I need to know please?
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Just thinking at this stage as Mrs JW911 wants rid of the Freelander. We don’t want a 5.0SC but would consider a 5.0, which isn’t available in the U.K, hence thinking of the 3.0SC. She wants to steer clear of the diesels.
So is the 3.0SC worth a look? Is it reliable (by RR standards Laughing)?
Any other top tips please? 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #671607 20th Aug 2023 7:40pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Only thing with a 3.0 s/c is that they only come in Vogue SE guise, so spec can be lacking. I have never had a 3.0 but from what I have heard I don't think the engines are as strong as the 5.0 v8.
Good luck with your search. What's your criteria
Post #671609 20th Aug 2023 8:16pm
JW911
Not a diesel and not 12 mpg. I’m sure I’ll struggle through with a Vogue SE. Wink
Shorter journeys for the most part. The plan is to keep the Westie, which is a bit like the faithful old Labrador. It’s had as much surgery as a faithful old Labrador at any rate and we’re lucky enough to have another car when if something inevitably breaks. 2012 4.4 TDV8 Westminster
Post #671615 20th Aug 2023 9:37pm
DrF
I have run several 5.0 s/c and currently have one and I get 21-24 mpg on average. I am not sure but I would think the 3.0 S/C would have to work harder than the 5.0 due to the weight.
Post #671616 20th Aug 2023 9:41pm
AnotherMutley
They're quite rare but can be a bit raucous higher up the rev range and I don't think the engine suits the Range Rover.
Post #671626 21st Aug 2023 7:41am
IIRC they only did the 3.0S/C in the Sport in this country, could be wrong....... Thumbs Up Pete
Post #671628 21st Aug 2023 8:51am
AnotherMutley
They did offer them in the L405 in both old and facelift. They're just rarer than hens teeth.
I looked at one at Shukers in 2019 but felt the engine didn't suit the car and went with a 4.4 diesel.
Post #671630 21st Aug 2023 9:17am
Wow, as you say, very rare, I know from reading the US forums that it does less or similar MPG than the 5.0 S/C so not much point...!! Pete
Post #671641 21st Aug 2023 10:56am
Weegie
Power to weight ratio. Sad John
GAP iiD BT
Post #671643 21st Aug 2023 11:16am
AnotherMutley
Pretty sure it came from the F-Type, which it worked well in. You still get the same potential tensioner issue with the S/C V6 as you can get in the V8, but again, I think that has a lot to do with the frequency of oil changes.
OP, what about the P400 version of the L405, think they came out in the L405 around 2018 after V6 was dropped?
If you can, drive them both back to back.
Post #671647 21st Aug 2023 1:12pm
JW911
Thanks for the thoughts. The P400 with the kind of mileage I’d want is a bit too much unfortunately. I’ll keep looking and may try a 5.0SC if there’s one in budget. 2012 4.4 TDV8 Westminster
Post #672042 26th Aug 2023 8:35am
Mikey
The 3.0 SCV6 is essentially the same as the 5.0 V8, just with a smaller cylinder head on each bank
340bhp, so its not exactly slow
Still suffer from the same issues as the 5.0
Rather have an SCV6 than a 2.0 though Thumbs Up
Post #672053 26th Aug 2023 10:43am
