![]() | Home > General (L405) > 3.0SC. What do I need to know please? |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1465 ![]() ![]() ![]() |
Only thing with a 3.0 s/c is that they only come in Vogue SE guise, so spec can be lacking. I have never had a 3.0 but from what I have heard I don't think the engines are as strong as the 5.0 v8.
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 260 ![]() ![]() |
Not a diesel and not 12 mpg. I’m sure I’ll struggle through with a Vogue SE. |
I have run several 5.0 s/c and currently have one and I get 21-24 mpg on average. I am not sure but I would think the 3.0 S/C would have to work harder than the 5.0 due to the weight. |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
They're quite rare but can be a bit raucous higher up the rev range and I don't think the engine suits the Range Rover. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
IIRC they only did the 3.0S/C in the Sport in this country, could be wrong....... |
They did offer them in the L405 in both old and facelift. They're just rarer than hens teeth.
Wow, as you say, very rare, I know from reading the US forums that it does less or similar MPG than the 5.0 S/C so not much point...!! Pete
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Power to weight ratio. |
Pretty sure it came from the F-Type, which it worked well in. You still get the same potential tensioner issue with the S/C V6 as you can get in the V8, but again, I think that has a lot to do with the frequency of oil changes.
Thanks for the thoughts. The P400 with the kind of mileage I’d want is a bit too much unfortunately. I’ll keep looking and may try a 5.0SC if there’s one in budget. 2021 3.0 P400 Vogue
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
The 3.0 SCV6 is essentially the same as the 5.0 V8, just with a smaller cylinder head on each bank
