![]() | Home > Wheels & Tyres > L460 SV - 20" Wheels Possible? |
Westminster Member Since: 23 Mar 2017 Location: UK Posts: 140 ![]() ![]() |
https://youtu.be/R-VR5fuhiig?si=eRWwm9WSp3mOX5b_&t=32
255/60/20 is one of the OEM sizes on the L460. Mine doesn't seem to rub but have only used on the road for a short amount of time so far. https://www.wheel-size.com/size/land-rover...egion-eudm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
Any reason to have gone for the 8” wheels rather than the 8.5? |
Both of the Range Rover 20" wheel options on the Land Rover website are 8"x 20". Which 8.5" wheels are you referring to?
This style comes in 8J (LR153233) and 8.5J (LR153235), 275/55R20 is the 8.5 size:
Oh I see, they come in different widths, I didn't know that. I wanted the style 5134 not the 7020 anyway, don't know if they come in different sizes too.
JDT523 Member Since: 30 Dec 2023 Location: Buckinghamshire Posts: 2 ![]() ![]() |
Hi - interested to hear your views on the duratrac's from an on road point of view? I'm considering doing similar- I have to visit some fairly remote sites a few times a year; not proper off road but some fairly challenging unmade roads and farm tracks. OK in summer - less so in winter.... the thing is I don't want to ruin the ride / noise for thr other 95% of the time!! |
Undoubtedly they are a bit louder than normal road tyres or AT tyres, if you can live with it or not is a question that only you can answer after hearing for yourself I'm afraid. They are nothing like the noise from full mud tyres though for example.
Thanks for that! And apologies for the delay in response
fmb123 Member Since: 19 Apr 2011 Location: Hampshire Posts: 64 ![]() ![]() |
why has land rover done two sizes of the same 20" alloy? our current range rover l405 has 20" x 8.5". with 255/55r20. we are about to order a new L460. do we go for the 20 x 8" alloys with 255/60r20 or the 20 x 8.5" with 275/55r20? will be fitting General Grabber AT3's which come in both sizes. so what is the pros and the cons of each alloy size? i cant imagine it makes that much difference, so unsure why land rover did this. admittedly the nicer design (like Westminster's above) of the two 20" alloys available only comes in 8". 2017 L405 Range Rover TDV6 Corris Grey 1988 3.5 Range Rover Classic 1993 4.2 Range Rover Classic LSE |
davidmweston Member Since: 21 Nov 2022 Location: Kingston Posts: 2 ![]() ![]() ![]() |
The new shape Range Rover has a part called “knuckle extender” that is fitted to each of the front wheels. It is a “handed” part, so different for left or right. It is available, I think, in three sizes to suit 20, 21 and 22/23 inch wheels. It serves as a mud scraper to protect the brakes from scavenged mud.
Could it be that the L405 wheels will not fit the L460 without conversion bolts? The older 20 had flat-faced nuts and the new one has taper faced washers and bolts. You can get the conversion bolts to put the 405 wheels onto the 460 at about £90 for a set of 20. |
Nabbler Member Since: 11 Jul 2024 Location: South West Wales Posts: 125 ![]() ![]() |
I’m sure there will be a member locally to you to pop around and swap to see if 20’s will fit. Count me out though I’ve got 22’s. Can I ask how did the 20’s feel and ride on your previous car as I’ve got a theory that they may be more forgiving and be more comfortable than the 22’s. Plus more forgiving if you or a LOVED one gets a little close to the kerb ? 2025 SV P615 2021 SVautobiography Dynamic Black ( gone ) 1997 C140 Mercedes Benz CL500 |
