Home > Technical (L405) > Deployable Side Steps Playing Up
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Started with passenger side not going out, then going out and immediately back in.
Then drivers side started twitching when the door was opened.
Now both are permanently out but drivers side twitches when either door that side is opened.
Read through umpteen pages here searching and the cars manual but can't find anything on a reset or similar.
Is this a trip to the garage time?
Edit: accessing them via the dash screen and trying the 'roof access' feature gets some clunking noises and an 'obstruction detected' warning. 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #671227 15th Aug 2023 8:03pm
Gremlin500
I would try getting under there with copious amounts of ACF-50 and lots of cardboard to protect your driveway. Recently there has been lots of wet weather, and no doubt slight corrosion in the bushings: there are no lubrication points, so you really need to lube up a couple of times a year the keep the steps freed up. Not using the vehicle much will make things worse. If the power draw is too much due to friction, the motors will behave as though an obstruction exists, and fail to deploy.
There could well be other reasons, but try this first, as it’s both common, and a cheap fix! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #671228 15th Aug 2023 8:38pm
Triarii
Thanks. I'll give that a go. I guess the arms that push the steps out will be fairly obvious from underneath. 17 MY Corris Grey 4.4 VAB
Post #671231 15th Aug 2023 8:52pm
Gremlin500
Always glad to help Very Happy
Stuck outboard is good in a way, that you’ll have better access to the various pivot pins, and after letting them soak for a few hours, can give them a swift kick as you lock the vehicle, just keep your hands/fingers out of harms way! Thumbs Up
I just hope it’s nothing more expensive, good luck! “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #671243 15th Aug 2023 9:34pm
caymanblack
How did you get on Triarii ? As Gremlin said a massive lube up should fix your problem. overfinch modified
Post #671587 20th Aug 2023 11:52am
balsingh15
United Kingdom 2016 Range Rover Autobiography SDV6 Santorini Black
Useful thread. I’m experiencing the same issues and lubricating seems to have eased but sounds like I need to literally cake the mechanisms in ACF
Post #671837 23rd Aug 2023 1:22pm
Triarii
Lube up didn't fix it. When it was in for the MoT they put it on the lift (two new rear tyres needed) and lubed the points and couldn't get the passenger side to work - it just twitches when the door is opened. The drivers side is behaving now.
I have to chase up an incomplete service at the main dealers (they didn't have the fuel filter available believe it or not) so might get it looked at when its back in. 17 MY Corris Grey 4.4 VAB
Post #672178 28th Aug 2023 3:52pm
landy95
The bearing surfaces are not easy to lubricate as they tend to corrode leaving no room for grease to get through, best bet is to soak all the joints with penetrating fluid, even then its hit and miss, the problem being you cant really work the penetrating fluid in by pulling the bracket in and out because the motor works with a worm and wheel so wont move without power. I had to strip mine down and remove the corrosion from the bores of the alloy brackets with abrasive paper. Lubed it all with a spray can of lithium grease and reassembled, worked fine then. Good luck. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned 1991 Range Rover Vogue 3.9 V8.
Post #672187 28th Aug 2023 4:53pm
Phoenix
We used Wurth HHS2000 to lubricate these, never had one come back with the same issue.
Post #672195 28th Aug 2023 7:32pm
balsingh15
Thanks I’ll give it a go.
Triarii - let us know what the dealer says
Post #672396 31st Aug 2023 7:32am
Triarii
Local garage greased them up during MoT. All behaving now. 17 MY Corris Grey 4.4 VAB
Post #674937 5th Oct 2023 12:42pm
