Home > Maintenance & Mods (L322) > new rear discs etc TRW ?
dazk2001
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
just shopping for complete new rear disks pad shoes etc
on AF shop there is a Borg and Beck Kit for TRW calipers how do i know if i have TRW calipers 2008 Range Rover 3.6 TDV8 Vogue SE
Post #671216 15th Aug 2023 4:01pm
DrRob
TRW are OEM spec. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #671232 15th Aug 2023 8:53pm
garyRR
Borg & Beck are a budget brand
I'd go for something a bit better quality, such as Brembo / Delphi / TRW / Pagid. 2015 Range Rover Autobiography 4.4 SDV8
Post #671242 15th Aug 2023 9:33pm
Gremlin500
As someone in the brakes industry for more than 30 years, I can tell you that Brembo do NOT make friction linings or discs, only brake calipers, ditto TRW. No matter what it says on the boxes.
A lot of Brembo branded Chinese products exist, so you have to be careful if going for non-JLR stuff.
There are some good German aftermarket pads and discs around, Jurid, Miba or Pagid etc.
Try searching “brake pads” “brake discs” on these forums, lots of info already on here. Thumbs Up
There is a lot of bullsh*t ”smoke and mirrors” stuff on the t’interweb about brakes & friction, so take it all with a pinch of salt, and if in doubt, go for genuine JLR parts. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #671245 15th Aug 2023 9:53pm
Ennoch
I've long suspected ECP of doing some dubious things with some manufacturers and providing substandard parts, particular with discs and pads (as in they get cheaper spec components, even if from the same manufacturer). However, if as you say Brembo only makes calipers, who makes their discs and pads? Because all products are listed on their website, including their excellent high performance HP2000 pads (genuinely the best high performance street pad I've used in the last 20+ years and 750k miles). It's the same with Pagid. Their high performance stuff is great, like the RSL29's, but I've seen some horrendous stuff from ECP/Carparts4less that I've been asked to fit by friends in the past.
Post #671248 15th Aug 2023 10:16pm
JayGee
It's no surprise at all that a brand name don't actually make it's own products and they are outsourced. Doesn't mean it substandard in any way. 2012 TDV8 Vogue (L322)
Post #671254 16th Aug 2023 6:18am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Re: new rear discs etc TRW ?
If I am reading this correctly, you are asking how do you know of your car has the TRW calipers and not the ATE?
LR used ATE until VIN 5A999999 and from VIN 6A000001 they used TRW.
If you look at this page https://www.advancedfactors.co.uk/brake-parts-51-c.asp it shows you the 2 options. If in doubt message them with your VIN, they will quickly confirm.
Post #671255 16th Aug 2023 7:07am
philip1972
Just to add, if yours is a 2008 I am fairly sure yours will be TRW, but please check.
Actually, just check that page in the post above-there are options depending on your engine size too.
Post #671257 16th Aug 2023 7:08am
Philip
That will be surprising news for Brembo, who have brake disc factories around the world. They also don’t licence the Brembo name, so even if something Brembo isn’t made in a Brembo factory, it’s made for Brembo.
Post #671292 16th Aug 2023 1:03pm
Gremlin500
The Brembo brakes are manufactured in Nova Milanese, Italy.
The pads and discs are manufactured er, elsewhere in the world, and not in Europe either.
The problem is that there are lots of knockoffs on the market, which can look exactly like the real thing, I’m sure Brembo supply-chain QA is very good on outsourced products, but when you license out manufacture to some Asian countries, there is always some risk of compromise. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #671294 16th Aug 2023 1:33pm
Philip
According to their own website, Brembo have disc manufacturing plants in Europe, USA, Mexico, Brazil and China.
Post #671298 16th Aug 2023 2:27pm
Ennoch
That's a bit of a stretch to say they don't make discs or pads. Even if the factories are owned by third parties rather than just being offshored production in their own factories, they will still have their applied tests and quality control measures to their products, and if you take that view you could say that Land Rover don't make their cars because most of the parts are manufactured by other companies on their behalf.
There are many good suppliers of parts, but if you said they had to have their own factory and be made in Europe then you'd have a small list, and it would include garbage like EBC.
Post #671305 16th Aug 2023 3:57pm
