Home > Maintenance & Mods (L405) > 2017 4.4 Diesel - NOX sensor fault - looking for advice
Iandiver
United Kingdom 2017 Range Rover Vogue SE SDV8 Kaikoura Stone
Hi all,
My 2017 L405 RR/V had a full service in April at 41,000 miles, but this week I have a service requirement notice on start-up, as well as a notice to say that the Diesel fluid additive (Ad-Blu) has only 1500 miles left.
My local independent LR specialist has looked at the readings and a NOX sensor is the problem. He says that as the problem continues, it will eventually shut down the car and stop it being started.
He suggests deleting the EGR software system as an answer to this, as the cost of replacing and re-calibrating the sensor to the car will be well over £1200.
I'm not sure about this at all and wondered if anyone here can offer some advice ?
Post #671166 14th Aug 2023 11:40am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
You could always try cleaning the sensor as they can get sooted up.
&ab_channel=MillerFamilyFarmTrust
Post #671302 16th Aug 2023 3:36pm
Phoenix
Get a new 'specialist' because the one you're using has no clue. The downstream NOx sensor is post DPF so if that is sooted up then you have bigger problems. The EGR system will not cause SCR issues, the two systems work separately and target different emissions.
Without seeing the data I can't comment on the diagnosis. NOx sensors are prone to failure across all marques, the cost to replace & reset the drift values seems excessive to me. Again, a second opinion may reduce your costs.
Post #671488 18th Aug 2023 9:04pm
Mikey
If the Adblu low message is on the dash, it will store various NOX codes
With a faulty NOX sensor, id expect the EML to be on dash, but you don't mention this
As for the service warning, there is a known issue where the light doesn't reset correctly, and needs an IPC + PCM software update (assuming the garage didn't just forget to reset the light)
Don't part with your money just yet Thumbs Up
Post #671492 19th Aug 2023 5:57am
