![]() | Home > Maintenance & Mods (L322) > DPF or not |
dazk2001 Member Since: 17 Jul 2023 Location: maidstone Posts: 24 ![]() ![]() ![]() |
would my 2008 3.6 TDV8 have a DPF how can you tell if it has one 2008 Range Rover 3.6 TDV8 Vogue SE |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
It doesn't! The older I get, the more I realise that people confuse wrinkles for wisdom |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
When were DPFs introduced onto the 3.6 TDV8? Andy
They weren't!
Having looked at some other posts on here it seems some of the run-out facelift 3.6s did have DPFs. So, it seems it wasn’t the 2009 facelift 3.6 that was the change, but either as a late-run addition or only as an option.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
3.6 never had a DPF in the UK market BUT, certain territory's did sir... |
thanks fo the replys guys 2008 Range Rover 3.6 TDV8 Vogue SE |
