Home > Technical (L322) > DTC Codes |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3227 |
The GAP IID will always throw a load of spurious and false codes. For the water in fuel fault maybe change the fuel filter as this is where the sensor is. 2012 TDV8 Vogue (L322) |
1st Aug 2023 3:49pm |
Lordy9099 Member Since: 22 Jul 2023 Location: Manchester Posts: 22 |
I thought about doing this, thing is some people say the housing can be the culprit, it’s still under the dealers responsibility to resolve. Thing is if you buy the housing from LR it comes with a new filter, sensor and the housing, the filter is £100 alone and the sensor probably £160 and the housing is £411 if you buy the filter, then it’s not that and need to buy the sensor, then it turns out it’s the housing you pay almost half the cost + the cost of the housing again.
1st Aug 2023 3:56pm |
IID codes that tell you of lost communication with various modules are as I said 'spurious' 2012 TDV8 Vogue (L322) |
1st Aug 2023 4:28pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
As above, spurious. I get a few codes on mine when I plug it in for a monthly health check.
1st Aug 2023 6:00pm |
